Hello,
There are those competitions in Japan, where contestants try to get the thinnest shaving possible. You need to have a good plane, good sharpening technique and skills to get good results in such competition. Today I was ripping a 32 mm thick oak board by hand and I figured out I can do 1 meter in 8-10 minutes with a 22inch 8tpi saw. I have no idea if the result is good or bad, i.e. if I had a sharper saw and a different angle of sawing, I could get a better result. I am going to sharpen my 28inch 4tpi saw and see what I can get. I know that ripping wood is more of a marathon than a sprint, but nevertheless, I would like to ask if someone is willing to:
- rip any common hardwood for 1 minute with a saw he considers sharp and fit for a job and measure how many cm ( or inches) did he manage to cut for a duration of 1 minute. Then you can provide your results
You can give us statistics: wood thickness, wood species, saw manufacturer, saw length, TPI, and measured the distance from the start of the cut to the end. Maybe we can find a way how to get some common value that will standardize the result based on some ratios, hardness charts, etc.
You can also precut 1 or 2 cm before the start of the timer, so you will not be slowed down with starting the cut.
This is just an idea for getting information on what a good ripsaw can do.
Thanks.
Thanks.
