MikeW
Hey everyone,
Ever feel your late-model Disston #4 handle sucks? Or whatever brand?
Mine is terrible after a couple minutes of use. So a bit of wood and some time changes things.
I drew out the shape of a saw I do like the feel of, a Fulton backsaw, onto a wood blank. From there, cut the shape the handle with a BS and cut the hand hole with a coping saw.
When you layout for the holes, lay the blade on the blank oriented properly, mark the holes and drill them using an 1/8" bit. Then drill from the largest to smallest diameters. Meaning, use an auger or forstner for the heads, then the appropriate size bit for the through holes for the bolts and nuts on their respective sides of the handle.
Some more marking and drilling for the back's mortise, a bit of paring out the mortise and a whole lot of rasping gets you the result below--or better!
Take care, Mike
Take care, Mike
