Howdy,
I want to improve my dovetails. So am trying to refine
mtb dovetails. I had a load of sapele which I was using
to practice on, however all isn't rosy.
Marking out I get and cutting tails goes well.
Using a pair of dividers and sliding bevel.
I cut on the waste side of the lines and complete using a
Fret saw and chisel.
I then transfer to the other piece using a knife. I then cut again
on the waste side. Using Fret saw anxiety chisel again.
When I try to make the joint they are mega tight and end up
splitting the tails or pins.
I've chamfered the joints facilitate making the joints. I thought
the more I did the better images would become.
Angel this for fettl8 get to get a good fit or adjustments in my
Process.
I guess if anything gets its better to adjust the pins to for.
Cheers.
Process.
Cheers.
