Kalimna
- Joined
- 18 Nov 2009
- Messages
- 1,275
- Reaction score
- 2
Greetings Folks,
It started off as a "I'd like to make something for you and the baby, how about a rocking chair?" question about 13 months ago, and I thought at the time that I would have plenty of time to get it finished for when our baby was going to be born (end of June, as it happens). I was mistaken. Quite obviously! A little searching on Google pointed me in the direction of Hal Taylors website. A brief flurry of emails back and forwards and I ordered a set of his plans and instructions (more of which after the piccies), and planned the expansion of my tool collection. I decided that UK sourced walnut was the timber I was after, and after a little searching I found a few boards from a tree felled in an estate around Loch Etive up here in Scotland. Loch Etive is one of the most beautiful places in our country, so I was quite pleased with that. Unfortunately, the boards were a little over 1" thick in rough, not the 2" as suggested by the plans. I thought "Never mind, I'll just laminate them up." By the end of the project I had become fairly proficient at planing a flat surface. Also rather proficient at thinking "I wish I had enough timber of the correct thickness".
One point to note about Hal's method of working is that everything, but everything, is completed with the aid of electrical power. So a few methods, I had to adapt. As the project progressed, I also discovered I had underestimated the amount of timber required (yes, I know, eejit), which is why there is a patchwork appearance to the finished item. Having said that, I think the walnut/ash/cherry combo works well (all timber sourced from Scotland via the ASHS network). I finally completed the construction/sanding of the chair at the beginning of November, and put the last layer of finish (wax over tung oil) a couple of days ago.
I must also say that this chair represents a few firsts for me - first proper piece of furniture (a blob of elm on a couple of legs for a coffee table and a couple of simple rocking horses being the first), first time cutting tenon joints, first time laminating a curved shape (rockers and back slats), first attempt at carving, first use of veneer to correct a too-wide gap in the tenon joint and first attempt at the "How many new swear words can I invent as something else doesnt go according to plan" record.
Ok, the following piccies (hopefully) document, briefly, the start-to-finish of this project.
My thoughts on completing the project are mainly that I am happy with the outcome. It has been an extremely steep learning curve, and there are certainly aspects that I am not happy with (sloppy tenon/slot joints, use of inappropriate timber, finishing). Having said that, it really is one of the more comfortable chairs I've ever sat in (padded or not), and I managed to finish it before my boy is 6 months old! Certain areas I found particularly tricky - getting the angles correct for the seat-leg joints and finessing the headrest/leg joints (planing on 3 axes to ensure a good fit was a stretch for me!) along with the finishing - I just could not get a coating of tung oil I was completely happy with. Hals instructions, whilst certainly comprehensive, were not always easy to follow, with mislabelled pictures and assumptions of up/top/down/bottom/width/length/thickness that had no corredponding diagram. But his emails were always helpful and reassuring when I ran into difficulty!
Please let me know your thoughts and criticisms (especially if you have also built one of these chairs), and many apologies for a rather long winded post!
Cheers,
Adam
Cheers,
Adam
