Before you glue all this together just make sure the neck angle is correct. I cant really suggest one because the top is flat. Usually on a steel strung the neck is pulled back by 1 or 2mm, that's known as a negative angle. On a nylon strung the neck is pulled forward by approx. 2mm.
It is possible to work it out by drawing the cross section of bridge, saddle height, fingerboard thickness, fret height and the 'action' that you are aiming for. In fact you might not need a neck angle, it's possible it could lie in the same plane.
That bridge is way too thick, it should end up near 9 mm, with your saddle projecting above this by 3.5 - 4.5mm (bass side) and 2.5 -3.5mm treble side.
Fingerboard is usually around 6 mm thick as a finished dimension. Check these dimensions with the folk over at mimf. I build nylon strung so dimensions are quite different.
Things start to get a little more critical from here on in. That's just to cheer you up.
