Ground clearance of pallet truck
RogerS
20 Feb 2004
In the eternally wet North
Does anyone have one of these and can tell me what the clearance is?
I'm kind of assuming that they are all much of a muchness but that may be wrong. Reason for asking is that my new toy is coming on a pallet and I need to build a temporary ramp up and over the door threshold into my workshop and don't want the pallet truck to get stuck on the apex.
OK
My pallet truck is as follows
Lowest ( Down ) measurement , 1 1/2" ground clearance
Highest ( UP ) is 6" ground clearance
all measurements in good old feet and inches :lol:
Blister":1ucvnp3f said:
OK
Does that include the clearance to the underside of the pallet Blister?
Just that 6" sounds quite a large clearance for the normal application.
Bob
9fingers":1b35jt9x said:
Blister":1b35jt9x said:
OK
Bob
The measurements I gave are from the under side of the pallet truck arms to the ground , with no pallet on the truck , I don't have a pallet here :wink:
The bottom of a pallet will probably be about 3"inches lower than the underside of the forks....
Blister":rvdachzo said:
OK
How many do you want?? My boss throws them away by the dozens.... :lol:
But yes they are about 4 inches high....so put them on a pallet truck and lose 3/4 inch plus the pallet trucks arm...there you have it.
Extra clearance can be achieved by using pallet truck to lift pallet off the ground.
Block up the palette and reposition pallet truck under lower laths.
Just need a little extra care that pallet does not slide sideways off top of forks.
Nice idea but I wouldn't like this to drop on my toes :shock:
Build ramp long, push pallet truck to top, lift/lever low end of ramp to give horizontal platform at same height as workshop floor.
After Hercules.
xy
Tony Spear":2c15tvve said:
I suspect somebody's just delivered a sneaky gloat! :lol:
Thought that was the hidden title of the thread. :twisted: :lol:
On the subject of pallet trucks, my work is just about to throw some out, anyone want one??
Aidan
