Epoxies and i think polyurethanes usually work very well on stone and concrete. Hilti have for many years offered a heavy duty anchoring stud that's bonded into a drilled hole using epoxy contained in a glass capsule.
Araldite is now owned by Huntsman, the TDS for their stone bonder is below.
That said whatever i was thinking of using i'd want to call their UK operation's tech support to verify the selection, as the potentially large differential in rates of expansion between stone and wood could cause joint failure fairly quickly. Thickness of the bond line (layer of adhesive between the surfaces) is probably important too for a product to be able to handle movement. Strength if you have a large bond area may not require to be all that high.
Chances are that the likes of Dow Corning (structural silicones used to bond tiles etc to buildings, or ship's decks, and Sika (mostly polyuethanes, but i think for similar applications) would be able to offer high flexibility options.
I've very successfully bonded lacquered birch to tiles using a high quality bathroom silicone - it's still perfect a year later.
ian
November 2007 Araldite® Stone 1800 A/100 B 1/3
Advanced Materials
Epoxy System
Medium-viscosity, fast curing liquid epoxy system for natural stone
processing applications
Applications Araldite® Stone 1800 A/100 B epoxy system is designed to meet todays demands for
innovative stone processing. It is especially suitable for:
slab reinforcement with mesh
Characteristics Araldite® Stone 1800 A/100 B epoxy system presents the following features:
high adhesion even to damp natural stone surfaces
stronger than stone
excellent breakage resistance
high moisture and chemical resistance
very low shrinkage
curing at room temperature as well as for accelerated oven cure
no solvent or styrene emissions
Technical Data If not mentioned otherwise, the following technical data describe the typical properties of
ready mixed Araldite® Stone 1800 A/100B epoxy system.
Aspect: transparent yellowish liquid
Color (gardener): <3> 95% of final strength) 2 hours at 40°C
1 hour at 60°C
TECHNICAL DATA SHEET
November 2007 Araldite® Stone 1800 A/100 B 2/3
Instructions for use
The stone slabs must be clean and dry before the ready mixed
Araldite® Stone 1800 A/100 B epoxy system is applied.
By weight 100 parts of the A-component must be homogeneously mixed with
25 parts of the B-component. (eg. 1 kg of A-component with 250 grams of
B-component). Alternatively by volume, the mix-ratio is 100 parts of the A-component
to 25 parts of the B-component. (eg. 1 litre of A-component with
250 ml of B-component) which must be homogeneously mixed.
Araldite® Stone 1800 A/100 B epoxy system can be applied manually, for example
with a fine toothed spreader or roller as well as by machine, for example by spraying.
Specialist firms have developed resin application equipment from meter-mix-
machinery to fully automated resin application lines. Huntsman will be pleased to
advise customers on the best choice of equipment on their particular needs.
All tools should be cleaned with hot water and soap before
Araldite® Stone 1800 A/100 B epoxy system residues have had time to cure.
The removal of cured residues is a difficult and time-consuming operation.
If solvents such as acetone are used for cleaning, operatives should take the
appropriate precautions and, in addition, avoid skin and eye contact.
The potlife of 250 grams of readily mixed Araldite® Stone 1800 A/100B epoxy system
at 23°C is 15 minutes counting from start of mixing. This time will be shorter for higher
temperatures and longer for lower temperatures. Similarily the potlife will be shorter at
larger mixed quantities and longer at smaller mixed quantities.
The open time of freshly mixed Araldite® Stone 1800 A/100B epoxy system applied in
200 g/m2 layer is 45 minutes at 23°C. Within the open time the mixture remains liquid.
The open time will be shorter for higher temperatures and longer for lower
temperatures. Also this time may be influenced by the ambient level of relative
humidity. Bonding of the mesh to the coated marble slab should take place within the
open time.
The minimum curing temperature of Araldite® Stone 1800 A/100 B epoxy system is
10°C. Below this temperature Araldite® Stone 1800 A/100 B epoxy system will not
cure sufficiently.
Stone surfaces coated with Araldite® Stone 1800 A/100 B epoxy system will be tack-
free and allow for further handling after 4 hours cure at 23°C. Higher temperatures of
oven cure will accelerate this process, for example at 60°C cure Araldite® Stone 1800
A/100 B will have tack-free surfaces which allow for further handling after 30 minutes.
Araldite® Stone 1800 A/100 B will reach practically full strength (>95%) after 6 hours
cure at 23°C. Oven cure at elevated temperatures accelerates this process, for
example strength > 95% of final strength of Araldite® Stone 1800 A/100 B will be
reached after 1 hour cure at 60°C and subsequent cooling.
Packaging Araldite® Stone 1800 A/100 B epoxy system is available in hobocks (27 litre for A-
component, 30 litre for B-component), 215 litre drums and 1000 litre containers.
Storage Araldite® Stone 1800 A/100 B epoxy system may be be stored in the sealed original
container in a dry place at temperatures between 2 and 40 °C for at least 1 year. The
product should not be stored exposed to direct sunlight. The expiry date is indicated on
the label.
Araldite is a registered trademark of Huntsman Corporation or an affiliate thereof in one or more, but not all, countries.
© 2007 Huntsman Corporation. All rights reserved.
