grand father clock
Andy
Don't know a lot about woodworking yet but I do know something about longcase clocks (my wife complains if I have all ours synchronized at midnight)
I would suggest that the first thing to do is make the seat board, which is where the movement sits, to fix down you use two u bolts which are easy to obtain from restoration specialist suppliers. Once you have this you can than make up a temporary stand which will tell you the important dimension which is height although this should only be one of two as I expect it will be a standard 8 day or 30 hour movement.
The temporary stand is one of the tricks of the trade for clock repairers as it makes working on a movement so much easier.
If you need the movement identified a couple of pictures will do.
Robin
This is exactly what I did. Good job too as the movement supplier told me one thing and the final dimension for the pendulum swing was almost an inch more.
I can hear it now, - tick, thump, tock, thump as the weight hits the side of the case. Not quite what I had in mind!
Also make sure you set the movement far enough back in the case to ensure the weights clear doors etc. (Don't ask how I know :oops: )
Stuart
thanks all for your replies, so much going on at the mo might have to leave it will lit you know if i do start it and try to post some pics
andy
