Yep works great until it leaks DAMHIKTTheres a video by "gid joiner" on the yootoob about this, he caps the end and then inverts the botle, it essentially seals it up, and then next time hes ready to use it, it just pops out like a plastic skin
I wouldn't know, i have never used PU glue, although I recently bought a bottle of Morells but its yet to be openedYep works great until it leaks DAMHIKT![]()
Here you go, Glues direct, a glue for everything & then some, polyurethane page here, Glues Direct,Please elaborate on the cheaper & better alternatives.
Since losing confidence in Cascamite I’ve been using PU more & more for exterior joinery, I’ve found during glue up the trick is to have a cloth with some thinners on for wiping fingers but most importantly under the cloak of darkness & while SWMBO is engrossed in some garbage on the box in the living room pinching a roll of cling film from the kitchen.![]()
Yep that would work but I like the clingfilm as in the case of covering the wood I can still see the joint.thick foil is also a good repellant for PU ooze)
You mean you don't have your own cling film?Since losing confidence in Cascamite I’ve been using PU more & more for exterior joinery, I’ve found during glue up the trick is to have a cloth with some thinners on for wiping fingers but most importantly under the cloak of darkness & while SWMBO is engrossed in some garbage on the box in the living room pinching a roll of cling film from the kitchen.
Not only does this stop the bloody stuff going every where I don’t want it but the thicker clingfilm peels off the glue & can be used again.
