Glue Question
Blister
10 Nov 2006
Boston Lincs
HI
does anyone know of a glue it need to cope with the following
1 must be clear
2 be able to stick polyester to wood
3 have a strong hold
4 will only be used on a item made for internal use
5 be easy to use , preferably from a tube with one of those cut to size pointed end things that screw on a tube
Not asking for much am I :lol:
All will be revealed when the project is finished :wink:
Blister":y0ko0n4d said:
HI
1 must be clear
Clear or colourless, or both?
Super glue?
OllyK":2iq9vbwj said:
Blister":2iq9vbwj said:
HI
1 must be clear
Super glue?
Both
I did think of super glue but its to watery / runny :cry:
Blister":1dblere9 said:
HI
1 must be clear
Super glue?
Both
There are thicker grades of superglue available.
When we had our windows replaced recently, the fitters used superglue plus an activator for a lot of the trim fitting.
Not sure what grade it was but it was made by Permabond
Good luck
Interesting website Travis.
Regarding epoxy: It won't stick to most types of plastic including Polyester if they are smooth.That's a useful characteristic if you want to mask areas to prevent epoxy from bonding and you can pop the cured epoxy out of your plastic mixing container. On the other hand, if you want to bond the Polyester to something else, it's not a good choice. Well, if the Polyester was in the form of a blue leisure suit, you could probably get the epoxy to wick through it. It wouldn't bond to the suit but to itself. :D
