GeordieTurner
Hi, what glue do members find best to stack pieces for segmented turning? Many thanks
+1 Completely agree with ChasCHJ":p7dtdm1d said:I use Cascamite adhesive, mainly because it does not have joint creep as PVA can with wood/humidity movements.
If you are making closed segment work, glue creep will show itself as a detectable ridge or step at the joint. It may not be readily visible but is obvious to the 'feel' as you pass your fingers over it.Simon_M":2bnx6q1t said:Bought some cascamite glue today, but not clear ..........what creep means or how it shows. .
