Glue for plane restoration
LocalOak
20 Nov 2007
Herefordshire
Hi
I've got an old wooden 22" jointer to restore and the tote has come free. The body and iron are fine, it just needs a bit of cleaning up, flattening and honing.
The tote is a good fit in the body and I was just wondering what glue would be best to stick it back down. I was thinking of cleaning off the old glue, putting a couple of short dowels into the body, matching them to the tote and glueing up.
My question is what type of glue to use? Is pva OK or do I need something extra strong? And are dowels a good idea or should I just rely on the fit between tote and body?
Any thoughts gratefully received.
Toby
LocalOak":2pse7zfz said:
Hi
Toby
Toby - if the tote has come free I suggest you sand it lightly to remove any dirt present on the suface and to remove any of the old glue. If the fit is a bit sloppy then a couple of dowels would beef it up a bit. As to the glue PVA ought to be fine and again if the tote is a bit loose then a gap filling adhesive like epoxy would do the job - Rob
Thanks Rob
off to bed now (yes I know, I really live on the wild side) but I'll sort it over the weekend.
Toby
The original glue would have been scotch (or similar). Using this is the only correct conservation approach.
As a "user grade" repair, any modern glue should be fine; if the fit is loose, a piece of veneer should serve.
BugBear
Well I've put it together now with a couple of dowels and some epoxy. I'm sure purists will be horrified but it was a very cheap acquisition and I want it as a working jointer rather than a collectors item.
The sole was a bit up and down but I've jointed that too and its flat, or at least flat enough in my judgement. I'm going to have to reduce the mouth a bit which is my first attempt at this type of repair.
But its the iron I'm most pleased with, tapering to about 3/16th at the business end and plenty of metal left, have already got it to a very nice edge.
Thanks for the advice, now its time to actually use it.
toby
If you're using it on surfaces to be glued, I wouldn't worry; what's a bit of tearout in a glue surface between friends?
BugBear
Good point but I am also hoping to use it for flattening some finished surfaces, maybe naively, but if I aim for that then I can come back to using it as a glued edge jointer when I miss:)
I thought jointers are/were only used for jointing(*1). For large surfaces e.g. tables, I thought the sequence was pretty much jack(*2), panel, smoother.
BugBear
(*1) doh!
(*2) whatever that means, see previous threads ad infinitum.
Bugbear
(*1) You're more likely to be right than I am :!: I may be using the wrong terminology, I should perhaps say jointer/fore plane. But basically it is 22" and I'm hoping to use it for flattening as well as jointing, to me its just a plane with a long sole that will be another tool for attempting to get at any bumps my jack rides over. I'm on a steep learning curve.
(*2) Help, I didn't even think about panel planes - that learning curve thing again :?
Toby
If it's any help this is what I do.
Cut a recess in the sole ahead of the iron and make an insert that will slide back and forth, opening or closing the mouth to as required.
Cut/drill a slot in the insert and hold in place with CS screw.
Better still, drill through the body of the plane and use a suitable bolt/M/C screw and a nut for easy adjustment.
