Doug71
MikeG.":odeyfp13 said:Doug71":odeyfp13 said:I am surprised that anyone would recommend anything other then safety glass, it sounds like the panes will only be narrow.......
Everyone thinks that "safety glazing" in the Building Regulations means either toughened or laminated. Well, it doesn't. There are other ways of showing compliance, one of which is to have small panes. From memory, there is a maximum width of 250mm and a maximum area of something like 1/2 a sq metre to fall within the category of "small" for the purposes of safety glazing. That's surprisingly big. If it is good enough for a house door, then it's good enough for a cupboard door.
I think from memory it has to be 6mm which could be a bit heavy depending on the cabinets, although if it is going in a groove to match some 6mm MDF panels could be perfect!
The thing I like about toughened glass is the nice rounded edges that you don't cut your hands on when you are fitting it
