RogerS
I remember seeing this some time ago that ade it easier to carry single-handed sheets of plasterboard etc. but for the life of me I can't track it down.
Can anyone help, please?
jasonB":1j4c4nid said:Whats wrong with your arms Roger, right hand under the middle left hand to steady the top. And you never leave them at home on the day you need them on site :wink: And less likely to slip when you have to tilt the board to go up stairs.
Also the board is a good 18" further from the floor so less likely to smash the corners.
Jason
gidon":llx6fdrl said:A method I've used (seen somewhere on the web) is to make a loop from some rope and hook it around the corners of the sheet and then use this as a carry handle - works pretty well.
Gidon
[EDIT - here's the method- although I don't botther with the hose and use thicker rope I have in the car for tying wood to the roof rack.]
