Frank D.
Hi everyone,
I finally got a few gauges done. The first two are standard marking gauges, made from bubinga with a tung oil finish. I made the blades from a hand scraper that I cut up. The locking mechanism is a wedged dowel, Jeff Gorman's idea, it holds the beam in place really tight and it's a lot handier than a screw mechanism; all you have to do is set the blade at the right distance, hold it in place with a finger, and tap the gauge (the end of the dowel) lightly on your benchtop. The diagonal wedging action also prevents the beam from rocking (racking?) once locked.
These two are hop or butterfly gauges. They're used to mark raised (diagonal or curved) surfaces (the beam is lifted high so the bottom of the fence registers on the reference surface, and the side with the knife marks the higher surface), or to mark over an obstacle or a convex curve (lift the gauge high so the bottom of the fence registers on the refereence surface; the arm goes over the obstacle and the pencil goes down the other side to the surface you want to mark).
I used the same wedged dowel mechanism to lock the pencils. All that is needed is a little thumb pressure and the pencil isn't going anywhere.
PS Don't tell anyone about these, two of them are supposed to be a secret until Christmas...Of course I couldn't wait till then to show you...
