Hi folks.
I'm making some twin gates at the end of my friends garden that backs onto a muddy lane. They won't be anything flash, just as cheap and easy as we can get away with. Probably just a simple square-frame with a diagonal cross brace from the bottom hinge to the centre of gates. Feather-board will then be nailed to this frame.
The posts are 125x125 treated timber, and are 6ft above ground. Here is the problem - the gates need to be 1.5m wide, but the posts are only sunk into the ground by 24inches!!
1) Not ideal obviously, but do you think the posts will hold the weight of a 1.5m wide gate?
2) What size timber should I use for the frame as it will be a compromise between strength vs weight reduction ?
3) How should I join the basic square frame before I then nail the Feather-board on ?
Regards
Joe
Regards
Joe
