J-G
I read virtually everything that is posted here (and learn a lot) but seldom post. Now I have a need for specific advice.
I've been asked to refurbish a Teak G-Plan table which has seen a goodly amount of use as a simple 4' circular unit and very occasional use with the centre leaf brought into play.
As you can imagine over the years the main table has suffered general wear and tear but the centre leaf hasn't so there is a marked difference in the appearance.
I'm looking for opinion as to how to go about this . . . purely mechanical -- sanding/scraping the surface or chemical -- remove what is left of the original finish using solvents?
There is some local damage which will require other work such as filler as well but initially I'm looking for advice on the best way forward and whether I should also strip the centre leaf back to bare wood since the chance of 'matching' seems remote.
Two photo's attached to give you some idea of the job.
It's been a while since I did any 'French Polishing' though I do have Shellac and Meths on the shelf.
