With the help of Sideways the research we did seems to suggest there are very few actual manufacturers of the compressors used at the heart of these type of units. Looking at the engineering of the actual box it sits in your not getting IMO anything more buying a top end brand than the cheapest.
The compressor used in this unit itself has been really value engineered. The windings are not epoxied which I would expect on any high end motor. The bearings were cheap no name ‘made in China’ and are as small as possible. They could have easily fitted larger bearings to make the unit last longer. The brush housings are horrible things. The good bits were the quality of the cooling fan and the length of the brushes
There is a built in life reducing feature! The bypass is letting air escape all of the time which in turn is heating up the connecting aluminium pipe and by consequence the lower bearing, motor windings and the hose. On the five stage units it appears they get so hot they are melting the standard hose in some cases. If the bearing gets too hot the grease melts out and the bearing fails which is what I think happened to mine.
I’m actually thinking of building my own air bypass for the unit which is actuated when the presume builds up or on the current drawn through the motor. Still thinking about it. The high end Graco units claim to have an auto stop on the compressor when the gun isn’t being used, but whether this alleviates the need for the constantly open bypass I don’t know. The main reason for wanting my own bypass system is that I will get higher pressure / CFM if it’s not open when the gun is being used and probably about the same performance as a five stage unit from my four.
So if I were looking for a unit again, I would probably buy a compressor and the gun separately. I’d buy the cheapest five stage unit I could find and again buy the Fuji gun. The Fuji gun has a pressurise gravity cup that helps with spraying thicker material I believe.
If I were to buy an all FUJi system I wouldn’t personally buy the Q, I’d buy the cheaper Mini system, it’s exactly the same unit I believe minus a bit of foam.
If I wanted a unit for my shop only, I’d probably buy a compressor and really top end gun with either a RPLV or LPLV Cap. I’m still researching this, as I’m thinking of moving to a static system.
