True you don't
, as I said earlier, a small bit of firewood ( dried out beam like that ) a little single hand axe ( what we call a hachette ) would do the job, and be faster.It's what I use to split stuff less than 30cm high when it is dry, unless it is also over 30cm or so diameter.Ever thought of wooden wedges like Inspector said, save you eventually mushrooming your froe, you can hit them ( wooden wedges ) to your heart's content, with no danger of a bit of metal chipping of and hitting you in the eye, I've seen that happen to someone hitting a bolster chisel to split wood ( si..si .. ) , it wasn't pretty, he lost the eye.
