woodbloke
I started the frame saw project today. I found an oddment of beech from an old sash cramp bar which I'm using for the main 'H' of the saw. You can see from the pic:
that the 12.5mm hole has been drilled for the handles (the square elm blocks) and the smaller hole is for the tensioning rod which will be a 6mm piece of studding. The mortises have been penciled in and will be cut with the router later on. All the tenons will be loose in the frame as the thing needs to pivot slightly as tension is applied...so the shoulders on the centre rail will be very slightly radiused. The black bit of stuff is an oddment of ebony used to prevent the frame racking when tension's applied and the silvery bit of metal is an oddment of titanium :shock: that I'm going to use for the blade plates that link to the handles. Also in the pic are the two bits of Dragon bandsaw blade that Ian let me have.
I've made the dimensions on the saw identical to commercial one's available from the Continent so I'll be able to fit a Turbocut Jap blade if need be later on. This is going to be quite a good little project...lots of shaping to do on the handles. It's essential though to make a full size drawing of the thing so you can work out exactly the correct size for the centre stretcher - Rob
