Frame and hammer fixings - any info?
gidon
19 Mar 2003
West Dartmoor, Devon, UK
I'd never seen or used these before but they look nifty. What exactly is the difference and what are their pros and cons does anyone know?
Can find very little info on them - they look ideal for attaching battens and such like ...
Gidon
Hi Gidon,
Do you mean like these http://www.toolmix.com/browse/range.asp?gid=912
Useful when fitting door and window frames and stuff like that. Put the frame in place, drill through the frame and wall then, without removing the frame, hammer the plug and screw through the frame and into the wall and tighten up the screw.
Used them when I fitted a new back door and frame. Brilliant.
Cheers :wink:
Paul
I used them to fit the 2x4 to my workshop wall (brick). Just drill a hole and hammer them in. Solid as a rock
The "frame" fixings are set by screwing in the screw/bolt and allow you to tweak the fixing by the amount you tighten it.
The "hammer" fixings are set by hammering in the screw/bolt which has a different thread form that only bites on teh pull. used more for carcasing and fixing battens etc.
You can also get a frame fixing that will tighten by expanding the part in the wall but will not pull the "frame" towards the wall, often used for UPVC where overtightening will didtort the frame, fill any gaps with foam afterwards.
Have a look on at Fisher Fixings for an idea of whats available.
Jason
I think you treat the hammer fixing as a nail so its hard to remove but the frame fixing is screwed in so can be removed and plastic sleave cut to remove frame.
