Hi Mike
I eventually got around to cleaning the tablesaw top. I discounted using the Green Webrax as whilst the top was very dirty it did not have any stains that I could see etc, also I was concerned that it may scratch it. Therefore applied plenty of WD40 and used Webrax 1500. It worked a treat, not too much elbow grease either-took 40 mins to do everything including the sliding table rails.
Turning to the scale for the lateral fence it is all but useless. I set mine at 90 degrees with a 12'' try square--not tried it yet so don't know if it will work. How do you set yours?
I'm not quite clear on how to adjust the table using Scrits method, it would seem that you would have to adjust the sliding table bolts underneath the table to achieve the desired result. Will have to experiment here I guess.
Whilst the saw moved very freely on its mobile stand before it had the rails and sliding table on, it is not so easy now everything is attached--although still moveable. The rail supporting leg does not present a problem as when the stand is in mobile mode it lifts it about 15mm off the floor, I make sure that the sliding table is at the far end of the rail though so there is no stress there.
Cheers Con
