markblue777
Hi all,
Looking at building a porch and I was going to make it part brick and part timber. I was going to have the brick part 500mm (or should it be more or less, im dont mind if it is just dpc height and then the timber frame sits on that) in height and then the timber frame built on top of that (probably going to clad in softwood pine painted or may just go for plastic)
My question is how far would I typically need to take the foundations for something like this and I have a soil line that runs outside my door (i will be building about 100mm away from it, possibly a bit more not 100% on the sizing yet) Do I need to dig to under the pipe to run the foundations.
The timber frame will be secured to the brick course and the back of the timber frame to the house wall, not sure if that makes any difference with regards to footing depths.
(separate note, does a DPC need running between the wall and timber frame where it joins to the house, I was going todo it between brick course and timber frame for the base so assume it should be done for the back as well)
Mark
Mark
