Forstner Bit Help please
Lightweeder
11 Feb 2009
Northumberland
I want to use a Forstner bit to make the recess for initial chucking, where it's possible. I saw a demo by a brilliant turner a few months back, and he advised me that he does just that, but that I should buy decent one - a Planet sawtooth, around 50mm. He apparently uses his for end grain. I did that - the cost was £14.34. Disappointingly, it's not performing any better than the cheap ones. Could anyone advise me please ?
LW, I don't think what you are experiencing is unexpected in end grain. 50mm is bigger than I would expect to be able to use in a normal home workshop pillar drill on end grain with any consistent success.
Do do so would require a cutter with considerably better cutting edges than you are likely to get on tools in that price bracket in my experience. HSS or Carbide versions could well be treble that price though, (I haven't checked lately they are out of my price range)
EDIT: See Here and Here for typical prices.
Thanks Chas. Clearly you're right, as something isn't working, and the bit is new, so it's not a sharpening issue. I was however hopeful when I had this particular bit recommended, but the proof is in the pudding, as they say :?
LW
How well does it cut in side gran. For big holes, I start with the big forstner and drill down 1/2" or less. Then i hog out the waste with smaller drills on the drill press, finishing off with the large one to give a perfect hole.
LW I have been down this road. The two bits I tried were not cheap but were also not up to the job. It's a nice idea to quickly drill out the chucking recess. But I think it's wishful thinking with low end forstner bits. If I was serious about it I'd but a Clico bit. Which, without looking, would cost £60+ :shock:
LW, if you can clamp your 'end grain' piece firmly to the table and the pillar drill has reasonable rigidity to maintain alignment, then you could try starting with a smaller bit and opening up to 50mm in stages.
This is what I did with the endgrain pencil/brush pots to be seen in latest Bits & Pieces below to remove the bulk of the material.
The rigidity is critical because the bigger bits will obviously have no centralizing guide.
Mike - couldn't get down anything like half an inch with mine.
Wizer - as you say, hardly worth the hassle.
Chas - I've tried clamping in husband's drill press, and I still only get a lot of smoke :oops:
Trouble is, I recall when I first went to woodworking classes. I was making a knife block, which holes in the top for dropping in cutlery. The teacher drilled the holes for me with a forstner, and it went through like a knife through butter. Must have been a real Rolls-Royce he was using.
Thanks all.
What I do when I want to use a large sawtooth bit is to take out the middle using a smaller one. To get round the problem of centreing is to start off with the large size and drill maybe 2mm deep. This will establish a centreing hole. Now switch to the smaller bit and drill out the centre. Then switch back to the large one.
This is all done on the lathe as I have no pillar drill.
This all seems a heck of a lot of bother to go to in order to make a recess for a chuck. I just do it quick with a parting tool. Hold the blank on the lathe with a plate or ring first on the top end then make your recess.
LW, the forstner bits are a bit like plane blades, there can be a significant difference in the 'sharpness' of the cutting edge associated with the angle etc. As you know a a general workshop plane that does all you need to take a shaving off a plank may not even look at end grain on the same board. It's much the same with forstner bits and they are far more difficult to refine the cutting edge.
Can you sharpen a pencil with your 50mm forstner bit cutting edge? I doubt it, and that's with the grain.
On side grain the bit is peeling as much as cutting short lengths of wood severed by the wings, on end grain it is chopping across solid wood.
Try cutting a pencil in half as opposed to sharpening it with a stanley knife to see the difference in driving power required.
The burning is because you do not have the power available to feed the cutter forward and at the same time turn it round, if your pillar drill is powerful enough (1HP?) and a good chuck fitted then applying a lot more hand pressure may get the cutter driving forward as opposed to skidding and friction burning.
What speed is your pillar drill set on when are you trying to drill the 50mm hole into end grain? Big bits need slow speed, with frequent removal to clear swarf and allow the bit to cool down. If you tried to cut to much too fast you have probably have overheated and blunted your forstner bit so it will need sharpening before another attempt.
When I first started making boxes, I drilled out the insides with large forstner bits (not the expensive ones either) on a pillar drill. It did work and I was able to drill holes 2" - 3" deep into end grain of various hardwoods. I stopped using this method as it was so slow (especially on boxwood!) and I found it was quicker to hollow out the boxes with a gouge.
tekno.mage
Duncan/Bodrighy - intention was to save time and effort with blanking plate or other mounting method. If I could do that, I would just turn a spiggot or a tenon.
Tekno - I take your point, and we did try slowing the speed, but it's not making any difference :?
Chas - I'm with you on this. I think it's because it's end grain, principally. It's 'Enid' by the way, and I'm still trying to come to terms with that, after all these years :cry:
Drilling a recess in the top of my bowl blanks is standard procedure for me. I use a 2 5/8 inch Forstner bit, and drill about 1/4 to 3/8 max. You do not want the blank to sit on the chuck, just like when using a recess or tenon for the bottom of your bowl. With the problems you are having drilling, it sounds like the bit is dull. Shouldn't be right out of the box, but might be worth checking by comparing to another new one at the store where you bought it. A good saw sharpening shop can resharpen them, but you may have to look around a bit as not all of them can do a good job. It is more of a specialty item. Drilling a recess is a lot faster than using a face plate, and for coring, your core already has a centering spot with the recess, and the chuck never has to come off the lathe.
robo hippy
Lightweeder":2svygyso said:
.... It's 'Enid' by the way, and I'm still trying to come to terms with that, after all these years :cry:
Sorry about that, knew it was an E, didn't mean to use it actually just had the E filed away in my mental database but the rest obviously got scrambled. Tend to ignore the LW which brings up visions of a Light Saber wielding ............ :twisted:
Either name sits well with me anyway, have fond memories of relatives with both names.
robo hippy":2ykkuw3c said:
Drilling a recess in the top of my bowl blanks is standard procedure for me. I use a 2 5/8 inch Forstner bit, .......
robo hippy
Not quite so easy in End Grain though RH.
Personally I adopted the use of a 10mm screw chuck adaptor in my chuck very early on to form an initial spigot/recess. This works well in both side and end grain and holds a 30+ mm blank if necessary to form main recess, the method also covers a fair percentage of my rough bark on blanks. I guess it's all down to personal preferences and sticking in a comfort zone that becomes somewhat automatic.
Just goes to show, we all have different ways of tackling this.
Chas - glad they're fond associations.
Thanks to everyone.
LW :wink:
I have recently bought some TCT Forstner bits from Hong Kong via eBay for really silly money!!!
The trick is to buy them in small groups at a time so that the total value does not exceed or even come close (value of pound can vary!) to £18 the limit to avoid import duty and VAT.
If you can wait the 10 or 14days for delivery you cannot beat this source. Typical price for 45mm bit is £5.41 INCLUDING postage!!!!!! NB Currently I am waiting for a 50mm bit to become available.
Just go to eBay at www.ebay.co.uk
And enter the search string:
Boring Wood Forstner Bit Set for Drill Hole Tool (it is how the Chinese interpret it!!!!) or simply enter: Forstner Bit (this shorter version will get you all the UK sellers as well). If you want to go direct to the HK sites/sellers use the first search string.
NB: you will need a Paypal account to make international payments but this is well worth having any way. This will enable you to make payments in ANY currency!
Or you can search for the supplier bestvaluezone but I wouldn’t recommend it as they have over 20,000 items!!! And there are more than one seller offering these bits so “shop around” amongst the HK sellers.
Just a note about “ragging” perhaps the cutter was working too slowly or you were using one of those “Silverline” bits with titanium nitride or tin coatings? They are somewhat crappy – excuse my French.
However, these TCT bits are very sharp and cut very cleanly.
Jonzjob":38c59id7 said:
An address for this would be nice pretty please Profax 'cause I for one might just be interested?? :D
I have a set of Forstner bits, but the start from small to not very big...
"Boring Wood Forstner Bit Set for Drill Hole Tool" (it is how the Chinese interpret it!!!!) or simply enter: Forstner Bit (this shorter version will get you all the UK sellers as well). If you want to go direct to the HK sites/sellers use the first search string.
Hope this gets through, I'm not sure how to activate the reply function
As the reply facility seems somewhat arcane and filters out urls then use a bit of nowse with www dot ebay dot co dot uk to repair the "report to moderator string generated in my reply
Be lucky!!!
yet another attempt! w w w dot ebay dot co dot uk
