jimi43
Off we go again...I had an hour in my workshop today and I had completely forgotten that I had this which was lurking on the bottom shelf in its box....
PRICE £90 plus post and packing at cost. NOW SOLD - SORRY
A VINTAGE STANLEY 45 "SWEETHEART" COMBINATION PLANE in near complete order as you can see in a wooden box.
There is a list of bits and bobs HERE on the Blood and Gore website...and I thank them for the opportunity to repeat here this list:
I will leave it up to the potential buyer to compare the list against the content shown in the photographs but I will say that this plane was used many times and some of the cutters have been reground/honed or replaced but most are unused.
A couple are additions to suit the job of the day! Note that the cam and stops are all there and these are the ones that go missing. Probably retained because this entire piece of magical engineering resides in its own plywood box...may be original...may be not...long before I became the owner though! There is also the bottom half of the cutter box.
This is the much sought after "SWEETHEART" model...not to be confused with later rubbish! This is a masterpiece of engineering which you can sit and play with for HOURS or just put it to work. It has more knobs than the Space Shuttle!
Condition is very good with no splits to either gorgeous rosewood original handle, knob and fence. It has hard resin from wood over most surfaces which could be cleaned off if you were so inclined...but no rust. Some tarnish to cutters as usual but no pitting.
Anyway...that is enough guff from me...I will leave you with some pretty pictures to help you decide and will answer any and all questions.
Any enquiries or if you want to buy this wonderful example...please PM me.
Cheers guys and gals
Jim
#1 Set of cutters (explained later).
#16 Main stock - the part with the rosewood tote and a fixed skate.
#23 Cutter bolt - wingnut-activated bolt to secure the cutter.
#24 Cutter bolt wignut - fixed to the cutter bolt.
#25 Cutter bolt clip and screw - secured to right side of the main stock to prevent the bolt from working free.
#27 Cutter bolt adjustment screw - the screw that engages the cutter with a pin on the bottom of it.
#28 Cutter bolt adjustment wheel - the wheel held captive in the main stock through which the adjustment screw passes; both #27 and #28 are used to set the cutter's depth.
#29 Arm set screws - the pair of screws that fix the arms to the main stock.
#30 Sliding section - the leftmost skate that is set to the cutter's width; it rides on two arms.
#50 Left fence - the adjustable fence that regulates how far onto the wood the plane makes its cuts; it is secured to the arms with screws and has a rosewood strip screwed to it.
#60 Long arms - a pair of round arms onto which parts are fixed to control the plane's cut; they're around 8 1/4".
#61 Short arms - like #60, only shorter; around 4 1/2" long.
#70 Adjustable depth gauge - an L-shaped threaded gauge that is fixed to the main stock.
#71 Adjustable depth gauge nut - the knurled nut that regulates the setting of #70.
#73 Adjustable beading stop - the L-shaped gauge that fits into the sliding section; a screw like #29 secures it.
#75 Slitting cutter stop - a stamped metal stop to control the slitting cutter's depth; it is located near the tote.
#76 Thumb screw - along with a washer, is used to hold the slitting cutter and its stop.
#80 Cam rest - a D-shaped stop that is fixed to the arms to give additional support when planing; this was added ca. 1905.
#81 Cam rest set screw - the screw used to secure the cam rest.
#85 Spurs with screws - the spurs that are fixed to the skates, forward of the cutter; there are two - one on each skate.
Jim
