Happy new year folks,
First piece of the year
My piece for critique #5.
Not quite sure what this would be called, its my first attempt at off center turning and pushed my little Axminster 900 to the limit. I wanted to try some more texturing.
Its 7" wide and 1" high from piece of seasoned European Oak.
A pair of screw chuckings were used in order to turn a pair of dovetail sockets for the smallest set of O'Donnell jaws
Turned with bowl gouge.
Finished with 80-400 grit then carved with the Proxxon Micromot and well burnt with the gas torch. Purple and green spirit stain added.
A test block with black acrylic and Jo Sonja’s iridescent paint.
I changed my mind quite a lot with the color with this piece and also made a few cock ups with the off center turning regarding my chuck socket placement and had the sockets overlapping slightly and even threw it out of the chuck at one point. I now know how to do right for the next time though.
I lost the use of the small off center chucking quite early on which was a pity as I had hoped incise some detail rings in order to get a real sharp edge between the texture and the off set bowl.
The foot is very poor but it had turned into a salvage job at this stage, any way the piece was saved and a lot learned.
Ended up with turquoise iridescent over black spirit stain for the textured area and blue over yellow spirit stain for the plain areas. Blasted the upper face with some acrylic lacquer and gave it a quick whiz with a Chestnut "C" mop.
Thanks for any comments
Tony
Tony
