siggy_7
Full time tool collector, part time woodworker
I'm currently building a pair of shelves for the kitchen, each will be around 2400mm long and 280mm wide. They are a torsion box construction and I'll be attaching them to the walls using steel studding resin-fixed into the walls.
My concern is that as kitchen shelves, they will be taking quite a bit of weight (cookery books, large Kilner jars and the like). I'm planning to use M16 studs, but the problem I'm faced with is the wall is single-skin brick. The bricks are quite old (the house was built in the 1850's) and previous experience has been that some of the bricks are quite soft. I've checked the load tables provided by Fischer for what I'm intending to use (FIS VL Vinylester resin) and the minimum insertion depth they supply data for is 120mm for an M16 stud. I'm particularly worried about the bending moments going through the fixing (60Nm quoted for insertion in cracked concrete at 120mm depth, or just 10Nm for M12 studs into solid brick at 50mm or 80mm depth).
If I assume a load is placed on the shelf 200mm from the wall, I'd expect around 2Nm of bending moment per kg of load on the shelf, so I'm quite concerned about getting enough strength from the fixings. I'm thinking around one stud every 300mm should be sufficient, but even then my shelf loading could be limited by bending moments to around 15kg/m which feels very marginal to me. Any guidance or words of reassurance from those who have done this before gratefully received.
