Doug71
I'm looking at doing a few floating shelves, it's something I haven't done much of before. The shelves are in alcoves so can have support at the ends it just doesn't want to be seen. The longest will be about 1.6m long and probably 250mm deep. They don't want to be too thick, maybe 40mm and will be painted.
Apart from the movement of natural timber does anyone see a problem with screwing something like a 20mm x 20mm batten to the back wall and side walls, taking an equivalent groove out of the back and ends of a piece of Tulipwood and just sliding it on? Obviously stopping the grooves short of the front and I realise potential problems if the alcove is wider at the back. I could offset the groove in the shelf so it leaves a bit more meat above the batten if you know what I mean.
I'm worried MDF ones would have to be quite chunky to span 1.6m and I don't really want to be using drilling threaded bar into the walls methods either.
Anybody do them this way or got any thoughts on it?
Thanks, Doug
Thanks, Doug
