I've got a lovely pre-war Record 5 1/2 which up to now I've used for initial flattening of boards before doing the final touches with my Veritas LAJ. The odd thing was that the Record would sort of give up and the LAJ would immediately take full width shavings. That didn't bother me too much because of the division of labour between the planes.
Then I decided to try to tune up the Record to see if I could get it working like a surgical instrument. Initial flattening with the sole marked up got rid of the very minor pitting, but the tail end, perhaps the last inch, was clearly high. So today I got a metal straight edge and found out that the sole is slightly convex in the length with the bulge being immediately behind the mouth, which is probably the last place you'd want it.
The best solution I can come up with is to hold the plane sole up in the vice, put some sticky backed 80 grit sandpaper on a flat block and work away at reducing the high spot behind the mouth. I thought I'd ask if that makes sense before launching into it. Are there perhaps other methods which would be better?
