Mike-W
I am making a small occasional table, the top is made from two pieces of Olive Ash joined down the length, the overall size of the top is 1000mm x 400mm x 22mm thick. The top sits on a pair of 'picture frame' legs with a rail running between the two end frames. There is only one rail at the back as I need to be able to slide two smaller tables in from the front under this table, giving me a nest of tables.
The end frame legs will be fixed to the underside of the top at either end solid Ash top running across the width of the tabletop.
I know the normal method of fixing solid tops to frames is to use buttons to allow for movement in the wood across the width of the timber, however I cannot use buttons because I need to slide smaller tables underneath the main table, I have set a tongue in the top of each rail and would like to glue this into a grove on the underside of the top. Given the length of the tongue (about 300mm) am I likely to run into long term problems with movement in the top, might I be better off using a flexible PVA type glue? Can anyone make any suggestions before I go ahead & glue this up?
Mike-W
Mike-W
