This coming week I need to install a frame for bifold doors. The head will be bolted to the flitch beam with 10mm stainless steel threaded bar which will enable me to adjust the fit with a spanner from above which ought to be easier than trying from below. The weight of the frame and glazed doors will be somewhere around 220kgs so needs to be something substantial. Then the 45mm thick door jambs need to be attached to the corner posts which are 100mm sq in 10mm galvanised steel.
So, how would you attach the frame (seen in the background) to the posts?
One thought is to drill and tap threads in the post. This is not something I've ever done, but I guess shouldn't be too much like rocket science. If this is the chosen route, any advice from those familiar with the process?
Alternatively I could drill right through the post and simply use a nut and bolt. The nut on the outside would be lost in the cladding which will be 30mm of celotex insulation covered by 20mm of iroko to match the frames and doors. Perhaps minimise the projection by using a half nut? In each case the head of the bolt will be recessed in the frame and covered with a matching plug.
Ideas please!
Ideas please!
