Fromey
My work shed was build by an unknown numpty lost in the mists of time but unfortunately I'm stuck with it. #-o It's a concrete slab with two courses of red brick, a damp proof membrane and then concrete blocks. It leaks water around the DPM in a couple of places when there is heavy rain. I've discovered one particular area inside which is a constant drip of water coming in over the TOP of the DPM (so much so that I have to put a drip tray there). This happens even in mild rain.
The culprit appears to be where the rain hits the external wall (the one that usually faces the prevailing weather), runs down the wall and then encounters the DPM where it pools and wicks into the wall, eventually reappearing inside.
I have a couple of questions of this esteemed forum (where I always get sterling advice).
i) Should the DPM be cut right back very close to the external wall or is it suppose to be about 5 millimeters proud?
ii) Would you suggest layering in some cement above the DPM to stop it leaking or,
iii) Squirting in a bead of external silicon sealant or,
iv) Fixing some sort of drip guard bead along the lower level of the wall (not very practical as it's the neighbour's yard).
My optimum solution would be to tear the whole abortion of a shed down and rebuild in timber, but I'm afraid that's not really an option.
Thanks in advance.
Thanks in advance.
