Wend
Hi folks,
I have a malfunctioning marking gauge. If I remove the sliding piece, then I can screw the thumb screw all the way in, and all seems to be fine. However, when it is assembled, if I try to tighten the thumb screw then it just slips, and will spin forever and never tighten.
I was thinking that I could fix this by drilling the hole a little bigger, covering the outside of a threaded insert (assuming I can work out what thread type I need) with hot glue, and pushing it into the hole.
Is that likely to work? Is there a better answer?
Wend
Wend
