Fitting friction hinge to windows.
Doug71
28 Aug 2016
Yorkshire
Hi guys,bit of advice please.
Is there a standard method of fitting friction hinges to windows?
I am making some stormproof type windows which will have the sashes hung on friction hinges. I have done a few before and have generally copied how they have been done on other windows in the properties. As these are not matching anything else I wondered if there is a standard way as I have seen them grooved into the frame, set against a small rebate in frame or just screwed to the frame. They always seem to be grooved in to the sash.
What is the best method people find? Think they are a 13mm stack height that I will be using.
Many thanks, Doug
Typically they are fitted into a eurogroove which is a double rebate.
most of these style windows have the eurogroove on all 4 edges so the espagnolette lock goes in the same groove.
Euro groove is 16mm wide.
Thanks Robin, I have a euro groove type cutter for the sashes, its more the window frame I was wondering about, do you fit them in a groove or just screw directly to the frame?
Please can you reply a bit quicker this time, I don't have time to sit around waiting :wink: !
These have been in 15-20 years.
I grooved into both the sash and the frame to minimise the gap between the two, this also facilitates a smaller rebate on the stormproofing to cover the gap and subsequently a smaller sash section
They dont go in a groove in the frame -they wouldnt open :D
Some manufacturers do a rebate that acts as a stop, although thats normally for the espag keep rather than the stay.
Just screw them straight onto the flat rebate using a timber packer to get the right distance.
Of course some windows have a sloping bottom frame rebate, or a check rebate -although thats usually flush on stays rather than stormproof
Mine must be magic ones then :roll:
