Hi guys,
So I have run in to a little bit of a problem.I am making some small inset doors for a shelving unit. The material I'm using is 16mm white pre primed mdf. upon drilling the holes for the cup of the hinges the brad point of the forester bit punctures the other side.
To remedy this I found a cheap old china 35mm forester bit and ground of the brad point but i still get a slight impression on the other side ( the cutters inside the outer cutter ring are slightly raised.
I know i probably should of gone with 18mm to avoid this but the cup should seat in the 16mm material with a 2-3mm meat behind it.
can anyone recommend any other methods.
I have a router so could maybe buy a top bearing flush bit and plunge and trace a 35 mil hole on a template. i have 14 doors to do so could take a while.
I also maybe have the possibility to borrow the eco drill jig from blum though I wonder if the jig works for 16mm doors as online it states only maximum thickness.
any advice would be greatly appreciated
