CynicalFox
Hi, my third post and already a request for advice from craftsmen. I want to build a fish tank stand for a 260 litre tank - so a total laden weight of somewhere between 300 - 350 kg. The design is intended to match as closely as possible to existing living room furniture so is perhaps not the most obvious from a structural point of view. My question and request for advice is this: is the following design likely to be strong enough to take the weight? There will be other features added (doors, tops, etc) but this is the basic load-bearing structure. Perpendicular joints will be mortice & tenon, adjoining faces will be glued and biscuited. Construction from an unidentified softwood from a builder's merchant.
