First turned item
Looking good V8. Better than my first turned pen holder which had a hole off centre to put the pen in 👍
Thanks guys, this afternoon it was back into the wood for another stick as my youngster wants me to have a go at a stool for one of her pot plants but first I must put a better edge on a chisel. Onwards and upwards hopefully.
Excellent.
Your wood would run truer if you had cut a tenon to mount in the chuck. It is the shoulder of the tenon against the front face of the jaws that keeps the wood true .
The tenon should be the size of where the jaws form a perfect circle which is normally when there is about a 3mm gap between the jaws & the tenon should be shallower than the depth of the jaws.
HTH
Write your reply...
