josephdouce
So I've been looking for table saws and been trying to balance economy vs quality and I noticed the Evolution Rage 5S and Bosch GTS 10 XC are remarkably similar, not sure if it's a rebrand or a straight up copy but the GTS is £600 compared to Evo £250.
Sliding mitre fence, extensions on both sides. Identical power button design/placement. Maybe some minor differences in the fences but if it's a rebrand it's a steal at £250.
Any comments/suggestions?
Edit Purchased Scheppach HS105
I bought a Scheppach HS105 and tore it to pieces, this is how it turned out.
Removed fence and extending table
Didn't bother with legs
Removed front and rear table extensions
Fixed guide rail for fence to front of table
I then modified the fence to lock only at front, as rear lock won't fit anywhere now.
I'm going make a cross cut and mitre sled and maybe a DIY fence but see how this one works for now.
Test Cuts
Fence Settings
10mm
150mm
300mm
600mm
Observed Rips 3 of each I rotated so 10, 150, 300, 600 so I had to re-set the fence for every cut.
10.5mm 10.2mm 10.4mm
150.1mm 150.5mm 150.1mm
300mm 300mm 300mm
600mm 600mm 600mm
I had calipers for 10mm and 150mm
Next step is to fit this soft starter https://www.bricoutensili.com/en/makita-spare-parts/10264-soft-start-device-for-bench-saw-makita-mlt100.html
Test Cuts
Fence Settings
10mm
150mm
300mm
600mm
300mm 300mm 300mm
600mm 600mm 600mm
