Phil Pascoe
Don't forget it's useful to have access to the right end of the lathe in case you do any long hole boring. You might not intend to now...but...
NickWelford":1kfstb7u said:There's something wrong. There's no sawdust and shavings...... It's altogether much too tidy!
Dalboy":1kfstb7u said:A very nice and well organised workshop. The table between the router table and your scrollsaw bench I presume that is the one on wheels. Will the lathe go there under the wood storage. Do you have anything under the scrollsaw bench if not can you make the small table just a little shorter so it can be stored under that bench when you are not scrolling.
The other measurments I said abot are when the head is being swung the front of the machine will need to be at least 500mm away from the wall. If you are thinking about the bowl turning attachment that will protrude out from the front of the machine by an extra 270mm. Even with these measurments it looks like you have plenty of room to stand and turn at the lathe.
phil.p":1kfstb7u said:Don't forget it's useful to have access to the right end of the lathe in case you do any long hole boring. You might not intend to now...but...
The lathe is the same as http://www.axminster.co.uk/axminster-hobby-series-awsl-woodturning-lathe.PeteG":32ogu58s said:I'm not ready to order just yet, but before I get carried away has anyone got any experience with the Rutlands lathe?
The full kit is £300.00 with starter chisels and a chuck!
