First ever project: Spice rack from pallet wood
PennineRider
8 Oct 2016
Ripponden, England, United Kingdom
Probably not the most impressive job ever to have been posted on these boards, but...
I had a pallet left over from a gardening project, so I decided to get the tools out and make something for the kitchen. It's not the neatest job but my other half is happy :)
    198.5 KB
    215.3 KB
    220.4 KB
Nothing wrong with that, plus the bonus points scored with the OH, gotta be good. :-D
MattRoberts":1dkenyfd said:
Looks well made - great work for a first project.
Now you've done it, would you change anything if you did it again?
Thanks.
I would sand off all traces of excess glue before applying the wood stain. The result of NOT doing that can be seen in the second picture.
I like the naïve, rustic simplicity of the build, but to develop my skills I will try something more ornate next time.
I would take more care with the router/build a better router jig to get neater and more accurate dados. Or I would stop being so lazy and chisel them out by hand :D
I would use headless panel pins to pin the shelf fronts into place, rather than being impatient to finish and settling for the ugly headed ones I happened to have in my toolbox.
I like the proportions - designing well is much rarer than making well, IME.
The only issue I see is that on the lower shelves, the next-shelf-up, combined with its quite thick retaining wall, obscure access, for both hand and light.
BugBear
