first box / tester
Lark
22 Sep 2007
Northampton area
i made this out of 12mm mdf and then veneer it with a vinyl bottom
in the idea to improve my skills with veneer as i want to make my new speakers so i fort the practice would be good.
i did have a few problem being varnish on to thick so i did have to take all the paint off
so ended up thining it by 50% ish and then wiped it on with cloth
used felt rather than velvet but this only cos it was a tester and thats all i had
used 1 hinge rather than 2. did not want to waist them.......
comments are welcome good or bad.
Nice box Lark =D>
So, are you going to use the same construction techniques and MDF on the speakers?
have to excuse my English as im dyslexic some times don't make sense
hey mike yer i posted about them on you page loved the work for all tables and bed plus the loft
you must be very good i guess you had to make up your snooker table
up as there very big :)
the main thing comes to mind seeing the speakers is the edging guess you have used a router, chafer or like roundover but then got the veneer over it as well.... would be nice to know how to, as it looks nicer than plain old square edge.....
plus i see slot port rather than the plastic tube port. i know slot for subwoofers mainly car. so that might be interesting if there maybe a program for that as the maths can be a alot to work out :) for the one you have done what looks like its as wide as the wood as in the side of the speakers are also the sides of the port.
i use avforums and diyAudio they are very up on alot speaker stuff
tony i will use mdf as i get on with it alot better then ply and ill dye it black might use beech veneer.... and jasper circle jig is great for the speaker holes. but i guess kinda the same way with bracing in side
i tried iron on veneer and it scared me away from it for awhile but the glue on veneer is quite easy to use
speakers i have already made.
the speaker parts are from the B&W cc6s2 speaker were new managed to get them cheap and i have only used it 1 time as i have the real cc6s2 anyway but it does sound better might be because the speakers where new.... this vinyl self stick
and the subwoofer my first speaker i had ever made is tuned to 30hz for home cinema use would recommended 20hz for big home audio systems
Hi Lark,
My speakers are transmissions lines so internally there are a series of baffles which form a long taper from behind the drive unit to the port you see at the bottom. It's a different design to a ported box.
This http://www.iplacoustics.co.uk/ipl_m3tl_ ... n_line.htm shows the design and the pic at the bottom shows the internal layout.
Mine are made from 19mm pre-veneered MDF and the edges are done with iron on edging to cover the bare MDF. I made them with mitred corners at the top and then ran along the edge of the mitre with a straight router bit to put a 10mm (approx) groove along the top edges. I then thicknessed two pieces of solid ash into 10mm square strips and glued them into the grooves in the top edges.
Finally i made the front pieces from a piece of solid ash, cut them to shape, routed the edges with a 1/2 inch roundover bit and glued them to the front. Once that was glued on I ran the same bit over the top edges to round them over too.
I hope this makes some kind of sense. It is a lot easier to do than describe! I wish I'd taken some pics while I was making them.
Mike
mailee":2fkb0kcp said:
That's nice work for a first box Lark. Just the thing for Christmas prezzies. :D
yer i hope to make some more using real wood and splines then use for gifts
Sawdust":3ji7cjiu said:
Hi Lark,
Mike
there like a big slot port...... the link to the speakers
i choosen my bookshelf ones to be the peerless hds +tweeter
i tend to go for looks when i buy
yes i have seen a video of the cutting the side with router using hardwood strip thats how i fort it might be done. might have been youtube
i am only part time worker and veneer mdf is about £40 per sheet or more bit much for me really and a starter in wood diy and speaker but speakers was reason why i moved on to more wood projects.
and i am learning by doing and internet videos. mostly Americans and then i found this site from lumberjocks they wanted to make an old english game. said said bout this site :)
