Are you only sanding with the lathe turned on.
If so after each grit and before moving onto the next grit stop the lathe and with the last grit you used sand the bowl following the grain this will help do this with all the grits.
As said before do not go to the next until all the scratches from the previous have gone ie start at 80 sand then go onto 120 but do not move onto the next until all the scratches from the 80 have been removed by the 120 grit and so on from there. Do not be tempted to miss a grit.
It can be a long process but well worth it
