Finishing black dyed veneer
Ian
5 Apr 2007
Northern Ireland
Hi All
I have a made a box that has had Marquetry with a black dyed veneer background applied and was hoping to use my usual finish of shellac and then wax, but after finishing the back of the box this way I noticed the pores of the veneer (which I think is sycamore) look sort of a grey colour. I am thinking this is light reflections but would like it to look more of a black.
I can't add a coloured wax due to the marquetry.
Any help would be great.
Ian
Tricky one, Ian. Cutting back with some steel wool to a matt finish would tell you if it is reflection. Given that sycamore is so fine grained, I think I would be inclined to add more coats of shellac and keep cutting back until the grain is filled.
Jim
Thanks Jim - when the surface is matt it is ok but the customer wants a satin open grain look.
If the box is tilted and moved around the light the reflections disappear - so from some angles it is fine.
Yes tricky one.
When it is cut back with fine wire wool it tends to have a dry unfinished look.
Ian
That seems to cinfirm the problem doesn't it. In that case, I think I would definitely go for filling the grain with additional coats of shellac. I have done this with quilted mahogany achieving an excellent satin finish with no visible open grain. it took time but was worth it.
Jim
