Fine adjustment of Bosch GOF 1300 ACE Router
militarymad
New member
4 Jan 2012
Crewkerne
I have a Bosch GOF 1300 ACE router, which I wish to mount in a router table.
One of the two plunge pillars is a large diameter than the other and has a fine depth adjuster on the end.
The router base plate has a 5.5mm hole drilled through it, which aligns with the inside of the larger diameter plunge pillar.
Does anyone know if this fine adjuster can be accessed through the router base plate with say a long allen (hexagonal) key or other tool?
I have been in touch with Bosch and they say they believe this can be adjusted using either a 5mm or 6mm allen key. The hole drilled through the plate is too small for a 6mm key and I have tried a 5mm and this does not work.
    192.9 KB
