niall Y
In the Metal Working rooms at school, more years ago than I care to mention, I vaguely remember using some form of filing guide. As I remember, every vice was equipped with some, They were L- shaped like jaw protectors but they had a hardened surface to the top. And, having aligned the line to be filed on the workpiece, to the top of these guides, you could happily file away until you reached the hardened surface. It was a very convenient way to accurately dimension metal.
Looking back, they were probably, made in-house, but I don't seem to have come across them since. I can't find anything similar on the internet, except for a rather expensive, over engineered, all singing, all dancing, version, with a carbide surface, used for knife making.
If I need something of this sort, it looks like I'm going to have to make it myself. The most convenient way to do this looks to be to use some angle iron, and then screw some smooth, replacement, vice-jaws to the top. There will be the curved fillet on the internal angle to grind away, to make them seat properly, but, hopefully, other than a bit of drilling and thread tapping, that should be it
Unless, of course, anyone can suggest an alternative. At the back of my mind, I also remember some form of sprung clip - a bit like a flat profile, split pin- that was held in a vice, and might have been used for sheet metal work.
