Festool planers
chippy1970
3 Jun 2007
London
Anyone got a Festool planer I am thinking of buying one need a bit of advice.
Got an old Elu one that i've had for years would like a lighter one so thought the one handed one would be good.
Thanks g-ster,
I think you got the wrong end of the stick I want to buy Festool and wanted to hear from someone who had a Festool planer for advice.
I have plenty of hand planes old Record and Stanley ones and I've had three Elu planers one of the best planers ever made in mine and many other peoples opinions. I don't need advice on them as I have been using hand and power planes for over 20 years.
Chris.
OK Chris I'll give you my two pennorth. I've recently been using a Festool EHL65E to shoot in some American oak doors (20 odd in total) almost all of which required adjustment (*?!@$! site chippies!). My planer of choice for about 25 years has been an Elu MFF80 which I'd agree is probably one of the best planers ever made and just about unbustable. In comparison the EHL I used for this job is a dinky little beastie and much, much lighter. Because of the spiral cutter (a single one BTW) the surface finish is noticeably better than the Elu, not that the Elu is that bad, it's just that the Festool is better. The dust extraction is excellent with the vacuum attached and the light weight means that it really is a one handed machine. The depth of cut is more precise than the Elu being "click-stopped" in 0.1mm increments rather than the Elu's 0.5mm marks with click stops in between and remember where you are after 1.5mm - you'll know what I mean. And the machine is quiet enough to use without ear defenders for short cuts. I didn't use the fence, although it did seem somewhat better designed than the Elu's fence, which as you know is a bit Heath Robinson.
Overall I liked the machine a lot.
What I didn't like was the cost of replacement cutters (check that out!), the fact that it can (for me) be a bit awkward to use two handed - in fact it is actually quite easy to try holding it in a position which puts your fingers near to the cutters, something I'll have to watch. I also reckon that this is much more like an electric jack plane than a smoother, so it probably wouldn't be the best machine to shoot an edge (unless of course the edge was already straight)
One thing I did find was that the cutter tends to start "rippling" the wood as it gets to the end of its' life, although that will easily take-out with a cabinet scraper.
Overall I think it's an interesting machine and probably worth the £225 or so they seem to go for. The only thing I'm not sure about is whether or not it would be worthwhile spending an extra £100 to get the HL850EB, although that runs at 10,000 rpm as opposed to 15,600 rpm of the smaller machine
Hope that helps and if you have any further queries please post again or PM me
the_g_ster":31xo6p2i said:
By a LN or LV hand plane, far nicer.
Maybe so, but not a realistic approach for hanging doors (says the man who carries a L-N #62 in his installation kit :roll: )
Scrit
PS Unlike others on this forum I'm not sponsored by Festool or any other manufacturers, worst luck :cry: :wink:
Just buy it, you know you want to. :lol: :lol: :lol:
Asking here and on the Festool forum suggest you really want one.
Well said Gary, What I didn't mention was that I went to Jaycee tools today and had a look at the 65 and it is good, did notice it doesn't have a detachable cable like most Festools.
The 850 is huge even bigger than my Elu so i don't think i will get one of those.
£10-00 says you'll be the proud owner of one by next weekend.
Can you bet me £210 please Gary then I can go out after next weekend and buy the Festool. :lol: :lol: :lol:
The EL65 is a cracking little planer and like all Festools, it does exactly as it says on the tin. It is light, easy to adjust and very accurate. The finish it leaves is superb and the chip collector can be fitted either side of the body which I have found very useful. The blade is about £8 but I have found that they last. I chipped one on a nail but still use it for rough work and swop over for the final finish. Blade changing is fast and very easy.
The power cable, like its big brother and the belt sanders, is fixed and I did buy a plug-it cable adapter to modify it but I haven't bothered and do not find it an inconvenience.
The 850 is a beast. Much heavier and certainly a two handed machine but it is a very powerful piece of kit. Its one big advantage over the 65 is its ability to rebate and should you wish, you can get different blades to give a rippled effect which is very effective for rustic furniture.
I really like the 65. It is easy to use, is excellent at chip extraction using either the bag or connected to a vac (CT Mini), leaves a beautifully smooth surface and is light enough for true one handed use. The side fence is excellent.
As Mrs Doyle would say, " Go on, Go on........and get one".
I bought it. :lol: :lol: :lol:
