Hi guys. I've had a Festool TS 55 circular saw and guide rail set for quite a few years, and am a big fan of the system - albeit that my new Hammer K3 panel saw hopefully means it will see much less regular use.
Browsing today i tripped over these add on 90deg clamping rails that fit on the main guide rail system - they basically allow you to to clamp it to a rectangular piece of sheet, and have a calibrated stop system for repeatable width cuts:
http://www.festool.co.uk/artikel/artike ... cfm?id=976
It needs proper thinking about, but there may be other uses for it as well, maybe even to help set up parallel rips off the sliding table on the panel saw.
Has anybody got any experience with it? Wonder if the dimension settings are accurate?
ian
ian
