Bought just over a year ago along with the rest of my CMS stuff, this was unpacked, checked and then stored on a shelf where it has sat [read: been buried] since. As such, it's in very good condition indeed as it hasn't been used.
The lot minus the included push stick
It's the insert for the Festool CMS mobile stand and this one takes the newer TS55 tracksaws, inverts it and gives you a portable table saw. The "R" is important as this is for the newer R[EBQ] models. Older TS55s won't fit so you need to be sure you've got one of the newer models.
Everything that came with the set is included:
Riving knife
Push stick
Protractor / fence
Height adjuster
Guard
Insert top
Insert underneath
It's been stored on a big flat shelf so it's still perfectly flat
Google says these are going for £330ish new. I'm asking £180 + P&P. The later will be from Shetland via Parcel Force and should come in around the £15 mark.
Riving knife
Push stick
Protractor / fence
Height adjuster
Guard
Insert top
Insert underneath
The lot (push stick missing but is included).jpg107.2 KB
Guard right.jpg113.2 KB
Height adjuster front.jpg217.3 KB
Plate flatness diagonal 1.jpg84.7 KB
Plate.jpg98.7 KB
Plate underneath.jpg83.8 KB
Protractor 45.jpg104.4 KB
Push stick (only one though...).jpg97.9 KB
Riving knife right.jpg93.8 KB
