• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Felder A741 single phase surface planer
Peter Sefton
Wood Workers Workshop
UKW Sponsor
6 Jun 2011
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
Very clean single phase Felder jointer with 410mm wide cutter block and 2000mm long beds. Note : This a dedicated surface planer, not a thicknesser. The quick change four knife block gives an excellent finish whilst flattening and edging boards. The four horse power industrial motor gives plenty of grunt on the most demanding of timbers leaving a mirror like flat finish. The easily adjustable in-feed table gives up to 4mm cut and has the space saving tilting fence attached to it, for accurate edging between 45 and 90 degrees on pre set stops. The simultaneously lifting spring loaded beds give easy access for quick knife changes and lock in place for safety. The Euro bridge guard adjusts smoothly and provides full cutter block coverage to the front of the fence whilst the crocodile guard keeps behind the fence safe. This machines has had very light use in my dry furniture making school workshop, is still wired up but ready for testing and collection.
£2800 no VAT
Available for inspection and collection Upton Upon Severn in Worcestershire
Peter
    178.4 KB
    159 KB
    187.5 KB
    144.3 KB
    116.5 KB
    181.6 KB
    114.4 KB
    122.3 KB
    122.2 KB
    144.5 KB
