Favourite hand plane and why
Indiana
22 Aug 2024
Bristol
Most of us probably have a go to plane for one reason or another. (Depending on the job obviously)
If you are like me an have a large collection then you’ll probably have one or 2 favourites
This one starts out when I was an apprentice
Back when you could buy things on eBay for 99p. I was just starting out and trying to build my tool box. One evening on eBay I saw a box of “carpenters tools”
Didn’t look like much sandpaper, steel wool
Some files. Box of old shed stuff really.
1 was the only bidder and including shipping was about £5.
When it arrived I was shocked
Right at the bottom was this Stanley block plane. Skewed rebate
I’m told they stopped making them just before the war
I use it pretty much every day for a number of things. Would be lost without it in the work shop
    2 MB
    1.8 MB
    1.9 MB
My record block plane is my favourite. Great for trimming small lippings and putting chamfers on edges . I’ve also found it useful for taking the rough edges from plastic cladding etc .
    2.4 MB
    2 MB
That's my goto plane for all the same reasons as you!!
It used to be a Stanley model with an adjustable throat and I persevered with it for many years - it suffered from the blade lateral adjuster moving with hand pressure - just bad design.
Later I inherited a very rusty Record 120 which cleaned up OK and it swiftly replaced the Stanley, albeit your's looks like it has a better adjusting and clamping design
View attachment 187579View attachment 187580
A true workhorse for not much money , I’ve had it + 25 years and it is still on the original blade . Yours looks like a much older model but has more or less the same shape. Good tool and clearly made to last . 👍👍
I have eight No4s. They are my most used along with a 4 1/2 so I suppose they're my favourite. I still have the one my dad bought me in 1981 when I got married. I will obtain more because I can't resist rescuing them for the right price.
Thought I was bad having 4 of them. It was 5 but I gave one away. There are also 2 wooden coffin smoothers and an old Mathieson infill smoother. I am also a sucker for old tools in need of rescue. I admit to likely having more planes than I really need but I could not single one out as a favourite. All the complete ones ( not in the spare parts box) are users.
John
no 5 1/2 is my favourite all rounder and a no 4 1/2 for smoothing, I don't use a block plane.
My two equal favourites:
- Lie-Nielsen bronze No. 102 low angle block plane
- Veritas NX60 low angle block plane - hmm, just had to look this up to check the number; it’s $504 (and not available), so I probably shouldn’t use it for the everyday stuff I do!
I have other planes, but these are the ones I reach for first. Why? They are both very comfortable in the hand - the Veritas is bigger and has more heft so is probably the more versatile. Both have thick blades that keep an edge for ages.
My Marples MA43 (Record 043 equivalent) is my favourite. It's small and fits comfortably in the hand, cuts nice grooves and gives brilliant shavings. I used it cross grain once (with deep knife lines) and it handled it like a champ.
My other favourite is Stanley 7 - not used often but a joy to use when it comes out.
Mine is my renovated Record no.4
I've fettled with it over time and it now takes a wafer thin sliver off even the sketchiest pieces and leaves a virtually faultless finish.
90% of the time I pick it up when getting ready to apply finish, and it's very rare I have to use scrapers or sandpaper (both of which I hate...)
I have 2 favourites, my two sons bought them for me which is why they are my favourite and choosing just one would be the equivalent of picking a favourite child........ :unsure:
Had them years, not even sure of the make, I would guess Quangsheng or similar :dunno:
Well you can’t argue with that
Come to think mine is the ECE scrub. Small and light but removes material faster than anything else.
I use it for cleaning up old reclaimed or painted timber, which I think is its original purpose - theres a clue in the name!
Then an old Record 5 1/2
I never got on with a 4 1/2 nor a 6, the 5 1/2 does for both.
Come to think my Stanley 3 is nice to use
and the 4.
the 7 is good.
and the Stanley 220 block plane - the older pattern with a wooden knob.
PS and the 5 is nice to use.
